hestleck
DRGB
I have a 95 sho that one day just cut off on me while I was on my way to taking it to the dealer to get my A/C worked on (BAD IDEA, DEALERS SUCK) and find out why it cut off. They said I needed or recommended to get a new TP sensor, IAC Valve, Camshaft sensor, and Ignition coil. Which they said all the parts were obsolete. Funny. I started my car or at least tried to and it would turn over but not start. It was trying to but wouldnt. Almost as if it was getting some gas for a second to almost start everytime i would turn the key. I put my foot on the gas and it would start, but whan I took it off it would stall out. So I pulled the codes to it and got a 33 (EGR valve opening not detected) and 556 (Fuel pump primary circuit failure). I am just about to buy the parts and find out if that will solve my problem. I started it today and kept it idled up and it was acting like it was going to stall out for a while off and on and after about 5 min of running it finally did. Any ideas on what is causing this issue?
