catilyic converter question
zach44102
BIG TURBO
Georgia
well i made the trip around town to get quotes on what it would cost to replacce the cats on my y pipe. well 1 shop told me to buy another y pipe. another said no way. another said that they will run it catless even though its illegal for 60 to 80 bucks. if i wanted cats then im better off buying a new y pipe. one of my friends who is a mechanic/body/paint man said he can gut the cats with a sizz wheel and weld it back up for 40$.. my question is would gutting the cats make it a little less raspy then a straight pipe? what would you guys do?
justin mccluske
washington
I did'nt see much of a sound differance when i gutted my cats. What i did on one of my other cars when it needed cats I just replaced the old cats with strait pipe and installed a single high flow cat where the y comes together.
zach44102
BIG TURBO
Georgia
well im getting ready to open up my cats and weld it back up. if i dont like it then ill just go with replacing wih the pipes
sperold
Last to Know
Do you know if there is anything wrong with your cats? I would leave them alone unless you have an issue.
I do know they are worth quite a bit at the salvage yard because they have some exotic metal in them.
zach44102
BIG TURBO
Georgia
well i just got done with my y pipe. i cut both of the cats open and realized one cat had allready been blown out it was empty. the other one i broke up all the honeycomb materiel and welded it back up. so my y pipe is allready to bolt up. catless magnaflow.
Clem
tooele utah
is there a reason you dident just cut them off and replace them with pipe?
zach44102
BIG TURBO
Georgia
yep because if your off just a little on replacing that cat the pipe will not bolt flush and create leaks.
Racer X
SHO Pilot, Retired
Connecticut
Two reasons:
- In a emissions state, a Y-pipe with no cats is going to look real bad during a traffic stop when the officer goes to look.
- Gutted cats will help keep rasp under control, where test pipes will be rasp city.
warmonger
earth
i live in ny aswell,the state where they pull you over for everything. i've never had a cop look under my car,even with excessive exhaust noise tickets. however leaving the shells in place is a good idea for visual inspections at inspection stations
zach44102
BIG TURBO
Georgia
plus the empty cavity will act like a very small resonator like he said keeping rasp down.
Sholovenothate
4 SHO's
Southern USA
I did the exact same thing on one of my SHO's a few years back. works great and I love it.
Good work man, that's how you save money =)
Clem
tooele utah
i will be running one magna flow cat a24 inch glasspack with straight pipe tails all 2 1/2 inch pipe i hate rasp i hope this will keep the rasp away i had this set up on my mitsu with a 18 inch glasspack and had no rasp till after 5 grand
moobypets
mooby
quebec
those are sho and rasp is alway there i was running straight pipe and it was still rasp in there almost gone but still there ..
moobypets
mooby
quebec
no glasspack and nothing else lol
but i do wonder what would be the sound with a glass pack
Clem
tooele utah
i think it is the cheap cherry bombs people use the rasp the good ones dont do it as bad
zach44102
BIG TURBO
Georgia
i used the name brand cherry bomb glasspack i think they where 40 a peice
shooff82
SHOOFF82
Hutchinson, Kansas
I was thinking of doing something similar; losing the cats, replacing the resonator witha long glasspack or bullet muffler and using chambered turbos or Edelbrock SDT muffs. I've heard the SDTs on other v6s and they don't seem to rasp too bad. Maybe use 2 1/2 pipe from the y-pipe back?
crystizel
