jruss1601
Heres the problem: It really has only happened at stop lights or areas where i'm stopped and idling in reverse or drive. The car stalls and won't start up immediately. It may take a few minutes.
I really didn't want to post about this because there are similar posts to mine but i just don't know if they are having the same problem. People suggested a crank sensor or alternator on the forums. My dad thinks its a bad fuel pump or flooding of the engine and can't be the alternator, and the guy across the street thinks its something electrical like a computer.
The first time this happened i was on an incline waiting on a stop light. It stalled and I couldn't get it to restart so i backed down the hill. stopped in a parking lot, turned everything electrical off and it started right up. Then i drove to the gas station thinking maybe i was low on gas? (i was only a little less than half a tank), then i drove to advance auto and had them test the battery. Battery checked out. This was about a month ago on a very warm day (about 75 degrees).
Nothing happened again til today. Again it was about 80 degrees. I backed out of a spot waiting for traffic to go by. It started back up and i went on my way. Down the road it stalled again in rush hour traffic. After it stalled if the car was able to start it would idle for a bit then just die again. Or if it would idle for a few seconds once i stepped on the gas it would struggle then die, if not immediately die. I finally got the car going then i got on the interstate to go home.(no problems). I got off my exit and back in town. Sitting at the stop light it happened again. This time it took longer and i was losing hope it would even fire up again. It kept stalling every time i hit the gas. Probably after 10 or 15 minutes of people honking it fired up, i threw it in drive, slammed on the gas and the tires squealed through the stop light. Then i was in my alley going to pull into my spot at the house and the car died again. I was so fed up i just got a neighbor to help push the car to the driveway.
Once we got in the driveway we tryed the car and it started up right away with no problems. Sounded strong too. We shut it off and tryed it again. This time it caught but the idle kept decreasing until it ultimitely stalled. He checked the fuel line pressure by that little nozzle and fuel sprayed out telling him the car was getting gas.
So again i'm sorry to post this. It sounds like a frequent issue in the forums but i'm just hearing so many conflicting solutions. Any ideas?
BTW, its a 95 3.2 ATX. thanks alot for all your guy's time
