SHO Mods
SHOCarGo
SHOCarGO
Utah
what are some cheap and easy mods for an 1992 sho. the car is quick, but a little faster wont hurt
Also, it is considered impolite to post essentially the same question in 3 different threads in the same day. Patience is a virtue, and searching the existing threads will not only prevent you from sounding stupid, it will also gain you a wealth of important knowledge.
Welcome to the forum, and to the SHO world!
SHOCarGo
SHOCarGO
Utah
sorry about posting so many times i didn't know if it worked. but i figured it out thank wont do it again..
needaQuaife
AKA: 5speedSHO
San Diego
Faster through the turns.
Have somebody weld in a steel bar connecting your rear strut towers. with two small braces going around the top. & handling, is now back. cheap, effective.
Vnuk1
Mr. Mayhem
Troof...
shobote
Naperville, IL
Cheap and easy is Mustang talk.... expensive and PITA is more accurate for modding a SHO. As said above first do all the 60k maintentance, rod Bearings, then suspension and brakes, then power adders.
SHO_ROLLER_2
Well-Known Member
Branford, Fl
That or LS1's!
****, you look at one funny and it MODS ITSELF!!
SHO mods+cheap=NO
