Groaning When Turning
SHO_ROLLER_2
Well-Known Member
Branford, Fl
It used to only do it when I turned left. Now, at parking lot speeds, she moans and groans when turning right or left.
I've heard other Ford cars that sound just like it, I'm just wondering what I need to change.
Thanks!
SHO_ROLLER_2
Well-Known Member
Branford, Fl
No, it sounds like it's coming from around the struts, I just don't know what it could be.
I might have to just get a video up.
needaQuaife
AKA: 5speedSHO
San Diego
basically, if you know it is coming from the strut area, then that is about the only thing it can be. Have somebody turn the wheel and lay your hands on the spring or strut mounts...
I had the same noise and when I put in my Konis, the old, original strut mounts and bushings were broken and falling apart. so when turning, the pieces were hanging up on itself.
SHO_ROLLER_2
Well-Known Member
Branford, Fl
You know, I can't remember if we replaced those when I did my struts and springs. I guess I'll start there.
How hard is it to replace them?
1stSHO
Asian Lover
Fort Walton Beach,FL
If they wont come out easy, just start it up and run it into a wall at about 70MPH....They will come out then!!!:sun:
AREA 91
Area 91
Sounds like it's time for upper strut mounts with bearings.
You will also need an alignment after the work is done.
