jonheese
Used-To-Know-It-All
From the continuing saga of my '90 3.2 & trans swap...
Okay, a little back-story, for those of you not following religiously (anyone? anyone? no?)...
The car's original engine and trans have ~293k miles on them, and 5th gear was making a "bad synchros" or "damaged gear teeth" noise, so I secured a 3.2 from a local (at the time) junkyard, and a replacement trans from a SHOForum member (who shall remain nameless until I work out how bad this whole thing is). Now, IIRC, the trans had ~92k on it, and there was "nothing wrong with it", although I don't remember why it was out of the car (wrecked?).
This all happened almost 3 years ago now, back in the spring of '07. It's taken me this long to get the 3.2 prepped and 60k'd, get the original engine/trans/subframe out of the car, and get the 3.2 on the subframe.
I know I'm an idiot for not inspecting the replacement trans closely the instant I got it (almost 3 years ago), but I didn't. I just said, "okay, it looks like it's all there, I trust the seller (???), great transaction, thanks."
So now I'm ready to put the trans on the block, and I'm swapping bits and brackets over from the original trans to the "new" one, and I notice this damaged mounting boss:
To compare to how it's supposed to look, here's a shot of the original trans:
This is the rear side of the case, where this mounting bracket attaches, with the bolt pictured:
So, I'm at a fork in the road. I can either a) just put all together anyway, leaving out the bolt (the mounting hole is totally stripped out and useless as-is), and or b) swap the internals from the (supposedly) good replacement transmission to the original transmission that has the bad 5th gear/synchros.
Option "a" is obviously more risky (depending on how crucial that mounting point is), but MUCH easier and quicker, and option "b" is a major pain in my @$$, but guarantees that I won't have any problems down the line from the missing mounting point.
So... What say you all? Is this a major issue, or am I worry about nothing?
Thanks in advance for any (experience) advice.
Oh, and also, there are no huge boobs, but here's a nice pair of ****, for anyone who just came for that:
