Gen 2 ATX Cooling Fan Replacement
FOMOCOTOSHO
I eat Rice.
Moorhead, MN
Does anyone know where to find replacement motors for the radiator cooling fan on a Gen 2 ATX? Mine are very noisy & annoyingly loud but still working..
I can find several listings for the LH (Driver's) Side motor from several manufacturers, but none for the RH side. I found an AC Delco listing for a motor that says RH or LH side, (Part # 15-8853) but will that truly work? I also found a Balkamp part # with the same description @ NAPA (Balkamp part # 6551807) Has anyone tried it? Is there any modifications that need to be done or is there another mother out there that will fit in the RH side specifically?
Thanks for any help in advance
sho'noffmtx
Many SHO's
Delano,MN
if you have a good relationship with your local napa and they would let you return electrical items if they were incorrect and didnt work, then i would say get them locally and just put them in. That way if something is wrong you can take it back the same day and tell them they made a mistake, get me the right parts.
or you could take your motors out first and compare them to each other to see if they look remotely close to each other. Good luck
The same motor should be able to be used in either side. It is only a clip that holds the fan on.
SuperHO
Mental Patient
St. Joe, MI
now's the perfect time to use an aftermarket fan. that's what i did when i couldn't find a motor for my MTX. works splendidly!
