Borla Exhaust for the SHO
SHOsc
South Carolina
Borla = 2.25" What is stock? what is NESHO's?
What is the correlation between the turbo and the exhaust that makes it most efficient? (Yes i have some idea, but would like to see some opinions)
-J
SHOsc
South Carolina
Just called Magnaflow and the gentleman said they are in the plans, but don't have a donor vehicle yet. He said it will generally take 30 days after that.
Or maybe he just had to tell me that...
beefcake
cincinnati, ohio
they told me the same thing last month, a guy i know says they are all done with it, so who knows
xxSHONUFFxx
CA
The vendor I purchased said they expect shipment in 2-3 weeks, which means I may have it delivered and installed before I go on vacation....plz, plz, plz...
PonySHO
FOG
Joe's Garage
I'm looking at modifying the catbacks only to get a little bit of a cool sound, emphasis on little bit. For you old fogies like me, they still make cherry bombs. I was thinking, replace the exhaust from the 3rd cat to the muffler with an X-pipe and a couple cherry bombs, leave the rest the same. JEGS still sells them! 545 glasspackstr They're $30 for the 2.25"ers. It's a glasspack muffler, 2.25" straight inlet/outlet, body length 18", 23" overall.
PonySHO
FOG
Joe's Garage
I made a quick picture using Kirk's picture of the stock exhaust. This isn't to scale, but it'll give you an idea of what I mean:
4168374343 c9e3446b28 o
PonySHO
FOG
Joe's Garage
I had a bit of an epiphany. The cherry bombs are just painted, I assume, and would rust. Summit makes a glasspack for $23, but I'm also assuming this is bare. Thrush makes a polished stainless glasspack, but the price reflects that finish, $95.
4168628579 29546c00d1 o
4168580621 ea735ca876 o
typhoon5000
Ferd Enganear
Shelby, MI
That sounds like a plan, but FYI, Cherry bombs will probably give you a lot more sound, not a little bit, as you emphasized. IIRC Cherry bombs just came back a few years ago after a bit of a hiatus. With the stock mufflers and cats, it might keep it farely quiet, by my experience is that Cherry Bombs make a lot more noise and are a bit too raspy for me :shrug:.
PonySHO
FOG
Joe's Garage
That sounds like a plan, but FYI, Cherry bombs will probably give you a lot more sound, not a little bit, as you emphasized. IIRC Cherry bombs just came back a few years ago after a bit of a hiatus. With the stock mufflers and cats, it might keep it fairly quiet, by my experience is that Cherry Bombs make a lot more noise and are a bit too raspy for me :shrug:.
Hey buddy! What gave me the idea was Kirk's video of his first version of catbacks posted a few weeks ago, http://www.nesho.com/Nesho Catback Exhaust.wmv Using that as a starting point, my intent was to quiet that down. I was thinking a combination of glasspacks and an X-pipe would change the characteristic of the sound some. Maybe an H-pipe would even have a different sound. Again, everything after the glasspacks would be stock. I'm looking for that "perfect sound", which is pretty subjective.
warmonger
earth
turbos help quiet it down a good bit. with stock cats and turbos you'd be fine running them i bet. btw,advanced auto sells glasspacks for like 20 dollars..have for many years
SHODWN
Mother Threasa
Spencer,Ma usa
Its a V6, glass packs will sound like crap! It will sound like a heard of bees coming at you.
I recently just got back from Dearborn, had some great meetings and got to see some amazing stuff..
Part of the discussions was about the exhaust, I was told again the the stock exhaust has very minimal backpressure, espically the cat back system. This coincides with my findings after doing a complete cat back.. I got nothing to speak of for all that money spent.
So with that being said.. if I was to do it again knwing what I know now and knowing that your only going to get sound, I would do what I did with my v8sho.
Remove the third cat and resonator and replace them with a x-pipe only, and keep the stock mufflers.
shobob
New Brockton Al
I took the car over to my friend's muffler shop and I got my first look under the car. I am going to take SHODWN add vice and just do the X pipe for now.
PonySHO
FOG
Joe's Garage
Are you going to also remove the 3rd cat, the muffler behind it and leave the rest stock?
