Eibach Springs Discontinued for the Taurus
_JR_
Toronto, Ontario
-10C isnt cold.....lol We can get alot lower then that.....you add the windchill and its really bad.
Good thing my SHO will be snug in my garage, that is, if it even fits in there lol
Still have to find that out.
Brent
Port Alberni, Canada
-10C is cold. Just not as cold as you would get. And it was aided by an icy wind to make it even colder.
And it stayed that cold for over a month straight.
zak
east of Hartford
B&G spring Rates:
Front:45 kg/cm = 256.99 lbs/in
Rear:34 kg/cm = 194.17 lbs/in
Matt, you mentioend before that the B&Gs are progressive. Are those initial, or final spring rate numbers?
The front Moogs are ~140 lb/inch initially, rising to ~ 180 lb/in after compressing them about an inch (as I measured on a peice of calibrated mechanical testing equipment).
Do you sell the fronts and rears (B&G) separately?
LOUDSHO92
Rancho Cucamonga, CA
Its the working spring rate. Basically where you will be most of the time when driving.
I can find out if B&G will sell them separately. I doubt that they will though as it leaves them with an unused front/rear. Any reason why?
Ill find out if they will if you are serious about buying them separately.
intimdatr
Got Cams?
Jefferson City, Missouri
Likely, after you post your order they will tell you that the order can not be fulfilled and refund you the money.
Not to say they dont still have stock left, but its unlikely. Id contact them before placing an order.
dinglefro
SlowSho92
Toledo, Ohio
Yea maybe that's true. That's why I'm buying a new set of someone nearby. $200 can't beat that with a stick.
gmail
Well-Known Member
sunbury pa
Really discontinued them? I got a brand new front set plus a set of cut coils.. heck I don't even want them haha
jimtash
nc
Your only chance at anything brand new is to keep an eye out on places like Ebay or here.
313tiger
