I am a "tire guy" and my own 93 atx SHO has 225 60 16 goodyear assurances on it that rub only when I have 4 people in the car. The tires do not appear to rub when the car is on a lift, there is probably an 1/8th inch space between the bottom of the front spring buckets and the inner shoulder of the tire, but if you get enough weight in it, it must flex enough to contact the tire. You get a hint of burning rubber, and I can see the wear mark, but if I'm in the car alone (which is 95% of the time) there is no smell. I haven't come across any good used 2156016 or 2255516(rare) or I would've already swapped them. Eventually I'll pay for some....
