#146 Black Limo for sale
SHOmanBC
Squamish BC
Time to move to a different class of Road Racing so the SHO has got to go.
1990 CACC chassis #175
Certified 8 point cage
Belts good till 2012
Stock 3.0 w/ 300klms
Recent rod bearings
Cams adjusted annually
Only Redline Synthetic used in engine & trans
New plugs and recent wires
77mm pro flow maf
Crank & Alt UDPs
High flow exhaust
HD engine & trans mounts
spec3 clutch & PP
Quaife
Aluminum SF bushings
Frame connectors
2 row rad
oil cooler
Koni Coilovers
Camber plates
TPR bushings
Aluminum rods & rod ends in the rear
H brace
rear knuckle braces
manual brake proportioning valve
TCE 12.2 x 1.1 wilwood road race pkg 50% pads
stock rear brakes with new pads
16x8 16lb wheels
245/45 16 khumo V700 new heat cycled from tirerack
Sparco sprint seat
Gutted 91 plus hood
Corner balanced
3025lb with 180lb driver & 1/2 fuel
Car is super reliable, well sorted and fast
1:19s @ mission raceway
Instruction / HPDE available if local.
$5500
http://www.shoforum.com/showthread.php?t=93137
pitaSHO
Why do I do this to myself?
Lewisville, TX
...and brake ducts, if I remember correctly. This thing is gutted and fast. Bump for a well set up track car. Best of luck on the sale.
Chris K.
SHOmanBC
Squamish BC
1987 944S, I'll run in Improved Prodution 2 ( 1.75 - 2.75L ) class, 188hp 170tq 2537lb race weight and a nicely balance chassis.
I can only hope it will be half as bullit proof as the SHO
89SHOMAN666
SHO NUT!
Reading, PA
It’s a shame to see another very knowledgeable SHO person selling their car. Lately many of the well known cars are leaving the original enthusiasts hands. Good luck with the sale, if I didn’t have way too many already I’d be all over it. Cars this well throughout and proven are few and far between.
Hope the next owner cares for it as well as you have.
Enjoy the Porsche.
GeneSHO
Canada
Is the Porsche 944S ready? Any serious interests on the Limo?
crystizel
