Loss of power when floored!
jjahamilton
CA
I have a '96 V8 and it has a major loss of low end power recently. It seems to be almost misfiring all the way across the tach when I have the pedal to the floor. It also likes to idle rough and feel like a misfire. I was told that it could be my canister purge valve malfunctioning and not allowing my emissions system to function properly. Any suggestions or advice? These are more irritating than limiting as far as drivability goes. I just don't want them turning into something major down the road. I should also ad that I bought a cheap coil from ebay a while back. It is not a Ford part. Think that might be a possibility?
Sbadass666
Saltlake
Hay yo its your maf-mass air flow meter it dirty&or cloged!!!take off your whole air intake pluming change filter if nessasery clean rubber tubes take off maf get a can of maf cleaner@favorit parts store first of coarse then spray in maf when out of the car!!clean it good in&out then do the throttle body&air mixture imac controll good open the buterfly on throttle body!!!
SHOspazz92
Banned
Triad Area, North Carolina.
What?
Check your Coilpacks, Clean your Mass Airflow Sesnsor, Log on to SHOcal.com and see if anyone in your area is able to weld Cams. Before you do any of that however, Go to a Autozone, Pep-Boys...etc and have them run the codes on your vehicle as it should make diagnosing the problem a heck of a lot easier.
-Sam
tardboy21
Woodbridge, NJ
-Sam
What he said. The FIRST thing to do is pull the codes, its a lot simpler to diagnose from there.
Griswold,CT.
mine does the same thing ran codes got p303-misfire on cylinder 3 done everything to it minus changing spark plugs,which is my next step and still have misfire on 3
