Autocross driving tips
shomesomesho
G-force addict
more rubber, more HP.....
Found these pearls browsing the web, thought I'd share them.
Andy Hollis is a multiple-time SCCA National Champion and 3-time Pro Solo class champion. He is also an instructor at Evolution Performance Driving Schools.
ANDY'S TOP TEN AUTOX DRIVING TIPS
[Just got back from a weekend of teaching Evolution schools and thought I'd share some stuff that I must have said a thousand times.]
1) Position first, then speed. Positioning the car perfectly is more important than trying to attain the highest potential speed. For example, you will drop more time by correctly positioning the car nearer to slalom cones than you will by adding 1 or 2 MPH in speed. Same with sweepers (tight line). Same with 90-degree turns (use all of the track). Also, position is a prerequisite for speed. If you are not in the correct place, you will not be able go faster. Or at least not for very long!
2) Turn earlier...and less. To go faster, the arc you are running must be bigger. A bigger arc requires less steering. To make a bigger arc that is centered in the same place, the arc must start sooner (turn earlier).
3) Brake earlier...and less. Waiting until the last possible second approaching a turn and then dropping anchor at precisely the correct place so that the desired entry speed is reached exactly as you come to the turn-in point is quite difficult to execute consistently. Especially when you consider that you get no practice runs on the course, and the surface changes on every run, and you aren't likely to be in exactly the same position with the same approach speed on every run, etc. Better to start braking a little earlier to give some margin of error. And by braking less you can either add or subtract braking effort as you close in on the turn-in point. This will make you consistent and smooth.
4) Lift early instead of braking later. Continuing with the philosophy of #3, when you need to reduce speed only a moderate amount, try an early lift of the throttle instead of a later push of the brake. This is less upsetting to the car, is easier to do and thus more consistent, and allows for more precise placement entering the maneuver (remember #1 above).
5) Easier to add speed in a turn than to get rid of it. If you are under the limit, a slight push of the right foot will get you more speed with no additional side effects. On the other hand, if you are too fast and the tires have begun slipping, you can only reduce throttle and wait until the tires turn enough of that excess energy into smoke and heat. Don't use your tires as brakes!
6) Use your right foot to modulate car position in constant radius turns, not the steering wheel. In a steady state turn, once you have established the correct steering input to maintain that arc, lifting the throttle slightly will let the car tuck in closer to the inside cones. Conversely, slightly increasing the throttle will push the car out a bit farther to avoid inside cones. It is much easier to make small corrections in position with slight variations in the tires' slip angle (that's what you are doing with the throttle) than with the steering wheel.
7) Unwind the wheel, then add power. If the car is using all of the tire's tractive capacity to corner, there is none left for additional acceleration. At corner exit, as you unwind the wheel, you make some available. If you do not unwind the wheel, the tire will start to slide and the car will push out (see #6 above).
8) Attack the back. For slaloms (also applicable to most offsets), getting close to the cones is critical for quick times (see #1). To get close, we must move the car less, which means bigger arcs. Bigger arcs come from less steering and require earlier turning (see #2). Now for the fun part... When you go by a slalom cone and start turning the steering wheel back the other way, when does the car start to actually change direction? Answer: When the wheel crosses the center point (Not when you first start turning back!) How long does that take? If you are smooth, it takes .25 - .5 seconds. Now, how long is a typical person's reaction time? Answer: about .5 seconds. Finally, how long does it take to go between slalom cones? Answer: Typically on the order of 1 second. Given all of that, your brain must make the decision to begin turning the steering wheel back the other way just *before* you go by the previous cone!!
Since this is a mental issue, a good visualization technique to get used to this is to think about trying to run over the back side of each slalom cone with the inside rear tire of the car. To hit it with the rear tire (and not the front), the car must be arcing well before the cone and the arc must be shallow. Attack the back!
9) Hands follow the eyes, car follows the hands. 'Nuf said.
10) Scan ahead, don't stare. Keep the eyes moving. Looking ahead does not mean staring ahead. Your eyes must be constantly moving forward and back, and sometimes left and right. Glance forward, glance back. Your brain can only operate on the information you give it.
Bonus Tip: Don't forget the stuff in between the marked maneuvers! Too often we think of a course as series of discrete maneuvers. There is typically more to be gained or lost in the areas that are in between. Pay special attention to the places where there are no cones.
Bingo: That old adage about either braking hard or accelerating hard is a road racing thing. Its usually attributed to the late, great Mark Donohue. It just does not apply to autocross, where there are many situations where you are maintaining speed. Like a sweeper, or a slalom, or things that are weird combinations of those. This is especially true in a Miata where you need only a slight lift to slow the car a bit and transfer some weight to the front tires.
Andy Hollis' Advices on Autocross Slalom
1) Start slaloming at the first cone, don't drive straight into the "slot" between the 1st and 2nd (hard to resist this). You'll still get a "freebie" but now it will be at the end instead of the beginning, allowing you to accelerate out of the element.
2) Line up 2-3 feet offset from a line parallel to the centerline of the slalom and turn before you get to the first cone such that the rear tires roll just by the back corner of the base of the first cone.
3) Start turning back almost immediately (this is the hard part because folks are used to waiting longer), trusting the car to arc around the backside of the second cone. If you wait too long, the previous turn will take you too far away from the cone centerline. Also, keep your inputs small. It doesn't take much when the arcs are shallow.
4) Repeat and rinse.
5) Use constant throttle once you achieve the proper speed to negotiate that slalom spacing. If you get "late", breathe the throttle to "catch up". Yanking on the wheel harder does not work (but is the typical response to being late). LFB folks can instead use a tap of the brake to catch up.
6) If you get "early" (unlikely), add throttle momentarily to miss the upcoming cone.
7) Always look at least three cones ahead, as you'll still see the other two in your downward peripheral vision. Some people look farther (4-6), but minimum is 3. If your eyes go down, you'll get behind and start hitting things.
When done well, it is a thing of beauty, especially in a Miata.
--Andy
Original discussions can be found here:
http://forum.miata.net/vb/showthread.php?t=44932
http://forum.miata.net/vb/showthread.php?t=285275
SHOspazz92
Banned
Triad Area, North Carolina.
Christ almighty. And to think I'm running CP with my Gutted and Caged SHO. I take a look at your Mustang and prey to god I never run in to it on the same Auto-X Course.
-Sam
Shoaz
Studly dood
Scottsdale, AZ
All of those points are very good, and, believe it or not, it all applies to road course driving as well. Well, maybe not the slalom stuff, but the rest of it. ;)
It's often hard to convice people of #3 and #4 (including a lot of supposedly experienced people), but I've found it pretty consistent that the guys that are really exceptionally fast do this. Learning to brake earlier, brake less, or just lift early has all sorts of advantages. Getting corner entry right is much more important than seeing how long you can stay on the power or how late you can brake.
SHOspazz92
Banned
I learned that lesson the hard way my first few Auto-X events.
-Sam
thebigjimsho
LSA = YUM
Worcester, MA, USA
When I finally figured out how to slalom, it was a blast! One of the best feelings in any motorsports event is predicting where the car needs to go and watching the car do it. A clean, tight slalom feels awesome...
DJSHO91
Durham, NC
There are quite a few points that can also help the open-road driver also. The fluid moves can make your driving more enjoyable, while also lessening the over-all stress and wear on your vehicle. I see so many folks(of all ages and sexes) who are constantly using their brakes to help control their car and truck. My favorite section on the road near my home is a down-hill s-turn about 3/4 of a mile in length with a 100ft altitude change.
89912922071211w826h629ppl23136111384 79
They go charging into the turns @ 65mph and then hit the brakes to drop down to 30mph. Or they will hit their brakes 18 times in the 3/4 mile stretch trying to stay in control. It's no wonder that front brakes are used up so quickly on most cars today!
The fun on any good road does not include the brakes, unless you have to stop.
SHOCH
Tommy Boy
near SHOcago
In the Chicago Tribune there was an article written by a guy who has written driving manuals, taught driving instructors, and has numerous trophies on several continents bla bla bla. but a few laps riding with Ron Fellows put his own abilities into perspetive.
He was in Vegas testing Vettes, Cobalt SS' etc., he got a ride in the Racing version of the 500 hp Caddy CTS V.
"The car was one thing, but what was really amazing- and humbling- was watching this man at work in "his office". You see acceleration is one thing, but in racing a good deal of effort goes into not losing speed.
After the first lap at speed I concentrated on watching Fellows, his eyes, hands, and feet. The mark of a world class athelete is gifted eye hand coordination. But what I noticed about Fellows was his incredable ability to anticpate. I had driven the same track on the same day with a Z06 and I thought I knew the track, but Fellows was traveling much faster and making it look effortless.
The smoothness of a true expert was clearly evident, the violent motions of the racecar seemed at odds with his relaxed grip on the wheel and almost subtle movements of feet and hands.
****Granted, his extremities were moving at incredible speed, but seemingly in anticpation of a need, rather than in reaction to one.*****
It took about half a lap before I realized that in my best moment I could not have played in the same league as this guy, and another half lap to feel totaly dejected by that realization. After that, I sucked it up and spent the remaining time reveling in the experience of witnessing a true world class race driver at work.
313tiger
