Hi all, I started having a problem with my transmission on Friday on my '97 SHO and its continuing. When shifted into drive it'll go ahead and accelerate through 1st but then will not shift into 2nd. It'll act as if it's in neutral and hit the neutral rev limited at 4,000 RPM. Sometimes it'll shift into 2nd and after warming up the problem seems to change or go away.
Here's where the weird comes in. By putting the shifter into 2 I get all 4 gears. It seems that 2 works like drive for quite a time until finally the transmission gets wise that its in 2 and then shifts back into 2nd. At this point shifting back into D lets it behave properly.
The fluid level and color is good. I have no idea whats doing this, but since all the gears seem to work, the standard practice of "Just buy a used one because ya know, ATX" doesn't seem to yet apply.
Anyone ever have a similar problem? The common sense in me suspects that the shifter cable is loose or something similar, but the "ya know, ATX" in me suspects some vague sensor somewhere along the lines.
Thanks for the help guys!
