95 ATX Green/Mocha Now on Ebay!
shocrates
will never know
NJ
95 ATX Taurus SHO
Green with Mocha interior
143,382 miles
Ebay Item number: 250449359256
Selling my very well maintained SHO. Interior and body are not perfect but still in very good condition. Superb mechanical condition. Drives like it has 20k miles, seriously. Everything works. I'm asking $2400 or best offer.
All pictures:
http://s735.photobucket.com/albums/ww356/95tshoatx/SHO/
001
003
004
011
016
028
-Ted B. LPM, makes the transmission shift great
-K & N air filter
-155 lph fuel pump with access panel under rear seat
-Oil changed every 3k or 3 months
-First front 60k done at 63k, changed timing belt, water pump, CPS,
front main oil seal, and new timing belt idler puller
-Valve lash done at 100k, new shims, valve cover seals, plugs, and wires
-4qts of transmission fluid replaced every oil change
-4qts of coolant replaced every other oil change
-Half quart of power steering fluid replaced every other oil change
-Throttle body coolant bypass
-Many bolts on engine have anti seize applied to ease repair
-All accessible wiring grounds in engine compartment cleaned and have
copper anti seize applied
-New water pump, radiator, CPS, and CID at 110k
-All rubber exhaust hangers replaced at 100k
-O2 sensors replaced
-Upper and lower radiator hoses replaced
-Cam seals replaced 143k
-Tokico struts, installed mounts and bearings in front and police mounts in rear
-96 front brakes, all rebuilt calipers painted silver, new flex lines
-All brake pads replaced with FORD pads at 130k, slider pins greased and
in good working order
-Moog springs in rear
-Aluminum Sub frame bushings
-Greaseable front sway bar bushings
-Moog sub frame strut rod mount repair kit installed
-Lower control arms replaced at 130k
-Moog sway bar end links at all four corners
-TPR bushings in rear suspension
-90 percent tread left on Bridgestone Potenza G009
-Clear corner lights
-Black "Powered by Yamaha" badge on rear trunk lid
-Viper alarm with remote start, I have copies of the installation and user guides
-Turn signal mod
-Fog light mod
-CD player replaced with properly functioning stock CD player
-Stock sub woofer works great
-Gas door release spring replaced
-Sunroof drain hoses secured with clamps
-Climate control blower motor replaced because it was making a ticking noise
-ABS fuse pulled, both front excitor rings are cracked, warning light on dash is blacked out
-Exhaust flex pipe mesh detached at front and rear, secured with hose clamps. Otherwise fine, no leaks
shocrates
will never know
NJ
BUMP
Found the cam seals to be leaking. Replaced them with Ford OE seals.
shocrates
will never know
NJ
Bump with lower asking price or best offer.
shocrates
will never know
NJ
BUMP.... going back on Ebay in June with no reserve.
GatorzRulez
florida
Hello,
If it is not to late, I am interested in the car. I didn't think I found it on Ebay, so maybe you hadn't done that yet.
Thanks,
Al
shocrates
will never know
NJ
Hi Al
It's not too late, the car is still for sale. I had the car on Ebay but it didn't meet the reserve. I was going to put it back on Ebay in a couple of weeks but would rather sell it outside of Ebay. If you want to discuss the car further send me a PM, or I can PM you my phone number and we can talk. Let me know.
Thanks
Greg
JRA2000TL
The Complainer
Daphne, AL
If you were closer I'd consider it. Seems to be very well taken care of and is very clean in the pics.
shocrates
will never know
NJ
Thanks! I've done my best to maintain it. Too bad you aren't closer...
