Yesterday I began stripping the engine in order to pull it out. I decided to remove the engine instead of droppping the transmision.
This way I can replace all the hoses, seals, clean the engine up, etc. I don't have to worry about holding the engine inplace while dropping the subframe to remove the tranny.
I think that my problem is the throwout bearing. I plan to replace the clutch, even though it only has 30,000 miles, but I do not want to this again any time soon. I may also replace the steel plate in the Fidenza flywheel. I have a SPEC Level II clutch, which I liked very much so far, so I may get another one again. Unless, of course, the problem happens to be the clutch, then I will be shopping for a better one. Any suggestions???
Anyway, I beleive that SHONUT has a ceramic throwout bearing. Are these better, stronger, more reliable?
BTW... the show that I am working on, "Savage Wild" hosted by Manny Puig, debuts tonight at 11:00 PM on "OUTDOOR CHANNEL". I am the underwater camera "A" on the show and make a brief appearance. Manny rides a huge 14 FT gator. See it and beleive it.
