noise between 4k and up
shoclown
shoclown
sacramento ca
after install of runners and bbb , i have alot of noise above 4k sounds like misfire. complete 60k with new plugs and wires done.engine is now all stock except bbb and ported runners and pcv catch can.
SHObill
'The Collector'
Rochester MI-48307Detroit
You made previous posts about 'her' feeling slower after BBB's & acid runners.
http://www.shoforum.com/showthread.php?t=96886
now you say you have noise after 4K RPM.
I suggested completely replacing the intake for a stock one before.
NOW suggest it even more!!
Do the BBB's have a new larger plate in them that seals well & do they open/close with no binding? Did you locktite all the plate screws?
Stock plates in BBB's will not 'feel' the same@4K. Loose screws on the plates will make noise untill they get sucked in to the combustion chamber & take out a valve & bind up a piston & then you will have some noise!
shoclown
shoclown
sacramento ca
loss of power and noise after 4k is whole thing. i assume i made amistake somewhere in the 60k so i have started over to recheck all i have done. i might have to switch out the bbb and runners (it is the logical step as shobill stated) just hate to if i am over looking something else.
shoclown
shoclown
sacramento ca
Firewall Firewall
1 - 2 - 3 Engine 5 | 1 Coil Pack
----------- Cylinder 6 | 2 Cylinder
4 - 5 - 6 Sequence 4 | 3 Sequence
Radiator Radiator
is this the correct firing order
Kens1992mtxSHO
The Commonwealth
Did you plug the butterfly canister in after the BBB install?? Are the vacuum hoses on properly?
shoclown
shoclown
sacramento ca
well its official i believe i am truely a dumb a**, While doing the 60 k i also painted my clipers and inner fender wells black and undercoated the plastic cover etc.
I was hoping it would help set off the recent wheel and tire purchase a little better (which it did)
iN the process of painting i had a really hard time removing the fender mounted k&n air filter due to stripped clamp. (i have what i believe is an older style air filter set up,it has a small alluminum plate that bolts where the oem air filter housing does ,then the air filter is a canister type that is actually under the fender well.
so where my advanced brain wirk has come to play is that becouse the clamp was given me problems i elected to leave it and was going to replace it at next air filter cleaning oil change.
so i decided to mask it with a small towell and some masking tape.
geuss what i forgot to take off????
even with all the bolt ons available no air (or low air) means low power and missfire
Kens1992mtxSHO
The Commonwealth
Well.... I have no comments.
:swing:
At least it's running properly again.
SHObill
'The Collector'
... the air filter is a canister type that is actually under the fender well. ... so i decided to mask it with a small towel and some masking tape.
---guess what i forgot to take off!!!!!!!!!!!!!!!
HaHaHa! now thats a classic OOPS!! now if I knew you were multi-tasking, I would of suggested you check that as I did almost the same thing-except I put a plastic bag over that filter!! Out of sight=out of mind!! LOL
shobroooo
