Need info on a.c/alt. bracket
Ghost93
Rockford IL
I have been having what I thought was motor mount problems on my 95 mtx.
I started poking around underneath the car and found that the cast iron backet that the a.c. and alternator mount to is broken. The car is a 95 mtx with a 3.2 and all 3.0 accessories, and has the 130 amp alternator. I dug around in the shed, and I have a 93 mtx bracket, and an atx bracket. Are either of these brackets going to be the same, or do I need a 94/95 mtx specific bracket. Thanks for any information in advance, Kevin.
Shoaz
Studly dood
Scottsdale, AZ
All the MTX brackets are the same, and the ATX brackets are quite different.
Has your a/c compressor been removed? That's usually why that bracket breaks. If so, you need to find a gutted compressor to reinstall or make a bracket brace to reinforce that cast bracket or it'll break again. The a/c compressor is a stressed member that helps strengthen the bracket.
Ghost93
Rockford IL
Wow, I love this forum, 10 min for a reply. Yes, I just got the car, and There was no a.c. compressor. That is awesome, as I have a couple of mtx brackets to spare, and I have a couple of compressors to gut out. Thanks alot.
Mr Anonymous
Tire Wall
St. Louis, MO
I hate to disagree with Eric, but I'm afraid I'm going to have to... :eek:
The '89-'93 alternator bracket and the '94-'95 bracket are indeed different on MTX cars. The ATX cars are even more different.
While you could technically make an '89-'93 bracket work on your '95, you would have to use the 90 amp Mitsubishi alternator and re-wire the regulator connection. Personally I would not want to go that route. You would be better off just finding the right bracket.
As Eric mentioned, the lack of an A/C compressor is a common reason for the brackets breaking.
Shoaz
Studly dood
Scottsdale, AZ
:theyareontome:
Ah...that's entirely possible. Evidently I've been lucky or something, as I had no trouble mixing/matching when I was fussing with that stuff with the Pumpkin.
