PacoLoco
I became concerned about the condition of my crank sprocket after browsing through the forum and reading about crank cancer. I changed my timing about 2 months ago. Everything went well, but maybe "a little to well." The crank sprocket came out to easily. The woodruff key didn't look damaged at all. The sprocket basically slid out without much effort. I read that many who have tried to remove the sprocket have had to use a puller in order to remove it. I didn't have to. Should I be concern? If I have to replace the sprocket, how much and can I get it from AutoZone, or only dealer? What do you guys think? The only problem I'm having with my SHO is that it jerks when I snap the throttle. Could this be related? What are your thoughts on this "jerking"? My SHO is a 1993 with 110,00 on the engine. Wires and sparks are in good condition, and no oil in wells. Still need to perform the valve adjustment. For those who reply to this thread, thank you in advance.
