Wonky Climate Control
Christian
Chilliwack BC CANADA
Auto Climate Control seems to keep cranking out heat and the car feels like a sauna. I set it to about 72 and the fan just keeps blasting hot air, to the point where it just gets too hot. I am still waiting for my manual to arrive from the dealer, but wonder if I'm doing something wrong. On my Lexus, it was a "set it and forget it" system, that never let me down.
Ideas welcome!
krewat
Long Island
Is it on Auto? If so, there's something wrong. Probably the temp sensor for the in-cabin temp.
glockcoma
That little bacon dispenser looking sign next to the steering wheel is the interior temp sensor.
Make sure it’s not blocked , I think there’s a small fan inside to circulate air around it.
A4f7c70912aa4e144b7de404b8372b57
Christian
That's the first thing I checked. As for the clicking? Nope all quiet.
Another electrical issue reared it's head today....I had my left turn signal on and after a few flashes, it stopped. I confirmed that the stalk was still in the left turn mode...nothing. Then put the right signal on and back to the left and it worked again.
jfalkingham
It's that time of year! Check for critters that might have setup camp or chewed some wire insulation.
Sent from my SM-N960U using Tapatalk
SethA
New Mexico
I'm not sure if this is the same issue I'm having, however
When I turn on my AC the driver side is cool air set at 68 degrees, but the passenger side is blowing hot even set at 60 degrees, anyone run across this issue?
