wll code 118 (ECT circuit open) cause a boosted sho to run lean ?
HotRodKid
mmmmm ... turbo
Western NY
the other codes seam to be 189 & 181 which are "Fuel system at part throttle rich adaptive limit, system lean" for the front and rear banks
the car has normal AFR's when theres manifold vacuum, but as soon as it starts to build any boost, it just pegs lean
tweecer is operating properly
MAF seams to be working properly, and was cleaned today
we also pulled the batery cable to reset the eec, no change
i know that some cars react horribly when the coolant sensor dies, im wondering if that could be the prob (or part of the prob) here
and the prob started instantly, one day it was fine, the next it was running like junk
any thoughts ?
HotRodKid said:
any thoughts ?
Fix the ECT problem.
FREAK_SHO
Wisconsin
It is a ~$20 sensor. Wouldn't hurt to replace it anyway. But I would say that could be part of the issue, seeing the computer adds or pulls fuel base on the sensor readings.
HotRodKid
mmmmm ... turbo
Western NY
problem will be investigated further tomorrow, as alex had to go get sleep so he could pull his next overnighter @ work. we ran out of time today
we didnt even have time to look the codes up online b4 he left, so there was no time to check anything based on the actual codes
HotRodKid
mmmmm ... turbo
Western NY
car was put IN storage, not realy put AWAY tho ....
alex left it insured & registered, i cant blame him either, cause it was expected that this might be a snowless winter for us
the car LOOOOOOOVES cold days .... and the chance to be able to take it out on ice cold days when theres not a flake of snow to be seen anywhere ... oooohyea
im ****** that we didnt figure it out today ... i wanted to do another WOT run down the highway ....
Axianator
I am a banana!
Roanoke, TX
Although the problems surrounding this car have since been addressed in another thread, I thought I would answer the thread's opening question by saying that, based on our current knowledge and understanding of the '94-'95 D4U1 calibration, an open ECT circuit (or code) by itself will not cause the EEC to command a lean fuel mixture.
