Windshield Wiper Fluid Pump Troubleshooting 94 SHO ATX
Edward Birdsall
Brewster, NY
Dear Shoforum, how do I troubleshoot windshield wiper fluid pump problem? The jets are clean and the wiper motor works when wiper pump engaged from wiper control. Thanks, Edward
have you followed the line all the way from the pump to the nozzles to ensure no breakage or blockage?
Irish Pride
Irish Inside
MusicCityUSA
Remove the line from the jet and see if anything comes out that way. If you know the pump is working and the lines are not blocked then the jet(s) have to be the problem.
sperold
Last to Know
You have to look under the inner fender on the passenger side, and most likely you will find the bottle rubber line has come off the pump discharge line at the bottom of the bottle. It does not have a clamp, it is a push on situation.
That would be the issue if you cannot keep fluid in the bottle. It will drain out in less than a minute if that is true.
If not, while you are under there, see if you can blow out the line to the windshield after you unhook it from the pump.
If you can blow out the line, have a new pump on hand to replace the old one while you are there. They are readily available as they fit a variety of cars and are less than $15.00.
The other possibility is you topped up with water, and the solution froze in the small diameter line, in which case you have to put it in a garage to warm it up.
Try the warm up option first.
I see you have an ATX. My experience is with a MTX, so the reservoir is under the hood rather than buried in the inner fender so things got a bit easier.
