windshield sprayers not working
bigcollins25
Washington, DC
yesterday morning I had to drive to Baltimore Washington International Airport. :omg:
It was one of those mornings where it had rained during the night and stopped raining in the morning with lots of excess water on the roadway. I used my windshield sprayers a lot. Then all of a sudden they stop working. I checked the fluid, filled it up and they still did not work. I still hear the same sound as when it sprayed (motor buzzing) but I get no spray!
1031070006
Any ideas guys? :wave:
stangeater
Farm Boy
Run new hoses, it's pretty simple. Also, did the ends freeze up? I've had that happen b4.
93rev2sev
Hockeytown
Maybe just a line junction broke. If you run the pump while you are sitting in one spot is there a puddle of blue stuff?
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
You could pull the little filter apart there next to the passenger shock / strut tower, then put a little compressed air on it. I'd probally recommend taking the ends off there at the nozzles so you don't super-clog it. I remember also having to get a needle out and pick a speck or two of dirt outta there once or twice. Make sure that little filter isn't clogging up on ya either.
bigcollins25
Washington, DC
Alright thanks. I will try pulling a few things apart to look for clogs. I have no puddles under my car if I try to use them so I am very sure I dont have a leak in the system.
I think it might be a clog because sometimes when I try to spray just a little 3-4 inch spray comes out the left side.
Thanks guys
pjtoledo
'ol man in the SHO
toledo,ohio,usa
the steel arm that goes from the motor to the wipers can rub on the driver side hose and wear a hole thru it. repair section of hose and move it out of the way.
Perry
362104
DV8
43*46'30"N 88*26'41"W
I had this happen to me earlier this year. I ended up installing a new w/w pump motor. Like yours mine was working then all of sudden it stopped. I was like wtf? It was probably the original one. Easy fix, under $20.
Keith
SHOtime3
DohcYamahammer
Knoxville, TN.
Got pics? My hoses were old and I pulled them off, but I've forgotten where they're supposed to run since then. I still have the little plastic vacuum thingy though.
shoclown
shoclown
sacramento ca
mine stopped and i found the squirters clogged i must of had some crap in the tank. i cleaned them with the files that came with my occy set torches
bigcollins25
Washington, DC
Hey thanks a lot guys for the help :thankyou:
Kens1992mtxSHO, Thank you sir. I will keep you in mind if it gets a little to overwhelming.
Waiting for the weather to fix the sprayers....
Funny it passed Virginia safety check without them working.....that check was a waste of time....:confused:
