Wierd clutch sound
SHO93OFF
Queens,New York
I hear this noise everytime I disengage the clutch (pressing clutch pedal down) its sounds like when u kick the pedals backwards on a bicycle, whenever I press the clutch pedal to switch gears anyone know what this noise is ?
JustinSane
SHO OFF
PA SHO Shop
the self adjuster "clicks" sorta like a freewheel bike rim. perhaps its that, but it shouldnt keep clicking once its adjusted so unless its broken in some way it shouldnt be that.
SHO93OFF
Queens,New York
actually now that u mention it my the spring behind the clutch pedal thats connected to the adjuster is not hooked to the hole on the pedal, ive tried to pull it down and get it in the hole but the spring is too tight soo i leave it hanging there, the pedal works fine. Soo maybe I should put a little more effort into getting that spring hooked into place and seeif it goes away
SHO93OFF
Queens,New York
Soo its been a while since i posted this topic and i still cant get that spring to go in its place anyone else ever have this problem, i need some ideas on how get it in place its a really stiff spring it makes it very hard to pull on to get it throught the hole.
poffffd
