Who'll do a 60k in the Toronto area
sho_racer
Guelph
hi i was jus wonderin any of you could help me find out where i can get the 60k mile in the toronto area.
or anyone by kitchener also.
venom
Rowboat Design
Toledo, OH
sho_racer:
I would post this in the Gen II section (seeing as you have a 95). I would also check the shotimes mechanics list of fame to see if there is someone listed there in your area.
Scott
Ian Macoomb
Ottawa, Ontario, Canada
If you've got a Gen III then you don't have to do a 60k. You can wait till 100k. But you'll want to have your plugs changed even though Ford claimed you didn't have to till 100k when they sold the car.
I think your best bet is to take it down to Kirk Doucette in Mass. He can weld your cams (if not already done), change your plugs, do the 100k and every other little detail that no dealer would ever do. It might cost you a little more than a dealer would charge to do but in the long run it will save you a lot of headaches and $.
I would still do the a tune up on the GEN 3 at 50k. For one this means you probably haven't had the cams welded. You can check on the rear valve cover wire loom and the plugs will need changing.
Ishodu
If you got a gen 1 or 2 I maybe able to help you do a 60K. I live in Hanover about 45 minutes away. Got the tools and the know how.
<small>[ September 15, 2003, 08:01 PM: Message edited by: Ishodu ]</small>
Diameg
Ontario, Canada
Hey there Marcel,
I'm going to need some help with brakes and rod bearings soon.
Would you be interested?
They don't necessarily have to be done the same day, but they are just the pressing things I have on my to do list, and I know that you've done both.
Mike T.
Ishodu
Yeah I can help you no problem. You doing a 96 upgrade? That takes about 15 minutes. I would think that both jobs could be done in the same afternoon. Email me and we can discuss this more.
