About a week ago at the most the '93 developed a loud, very loud, whirring noise toward the front of the engine (the accessories end). It sounds like when someone's straining the power steering at full lock (or a roots supercharger) but it does it constantly, turn the wheel left or right and no change unless, it only seems to change with the RPMs and when I put my mechanic's stethoscope against the housing it was quiet. Also I changed out the power steering fluid and nothing changed. Most idler pulleys I've had gone bad squeal so while I know I have one going I'm pretty sure that's not it, I've also heard it while this noise was going on. The water pump, if I remember correctly, also squeals when it's going bad so I don't think that's it either. I don't think the A/C compressor makes such a noise and it's actually working. Only thing I have left is the alternator but it's also quiet when the stethoscope is on the housing, a little bit of grinding but otherwise it's fine.
So I'm at a loss, the only real change I've made to the front of the engine in a while is the Gatorback belt I bought but that was about a month back and from what I've heard they don't whirr, they squeal or whistle. When I can I'm going to throw my old belt on there and see if anything drastically changes with the whirring, check the pulleys and accessories while I'm in there, but until then does anyone have any thoughts? :thankyou:
But I don't really have the tools to repack the bearings without ruining the seal. That and I already got one from SHOnut a couple hours ago, already spent the money.
