Which notch do i time with?
LJRuddy
Pop lock n drop
Poaceae fields
Well, my crank pully has three notches in it and i know i am supposed to use the white notch but all of them are not white... they are rust color :p Which notch do i use?
I have attached a pic off of my phone. Each socket is exactly where the three notches are. Any help is great!
Timingsockets
SHOBlu
Habitual Offndr
New Sharon, Maine
I can never figure out which one of those to use. FWIW, I use the mark on the timing belt pulley (crankshaft) and the oil pump housing. I think its at about 5 o'clock if you look at it strait on. The pulley itself has a little mark on the ******. Sometimes they are hard to see but they are both there. I align those marks and put the lower T belt cover on and then the balancer pulley to see which mark it is on the balancer.Then I mark it. I hope this helps.
Brad kirk
