Where to buy?
97V8SHO
V8's Own ALL!
Oklahoma
Where can I buy alum subframe bushings, front strut tower brace, 24mm front sway bar, and a 26mm rear sway bar? Does anyone know of a company that will make custom springs sence nobody that I know of makes em?
s9h9o
owatonna , mn
i got my bushings from Josh at www.shonutperformance.com , the subframe bushings i believe are available there also . Bob at (hey must be updating as i could not get the pretty pics on the url )www.anondamotorsports.com has the front strut bars fairly reasonably priced . try the sponsors headers above , too . the sways are available new from quite a few places , but check the classifieds first as the prices are in the 50 range . also do the rear first and try it, then with the strut bar ,then add the front bar ,if you feel you really need it .
<small>[ December 21, 2003, 01:24 PM: Message edited by: s9h9o ]</small>
Steve Dionne
Methuen, Ma.
Check ebay for the sway bars as they are listed there pretty frequently. MidWest SHO has the Aluminum SFB's. You might want to changeover to to poly endlinks also. Midwest carries these also.
David Carpenter
