Where do I splice in line for aftermarket boost guage?
Yipeekayea
I can't figure out where to splice the tube in for my guage. Before you say go by an Aeroforce guage....I'm broke and got this one for free lol. I'd just like to know how much boost I'm running with different tunes.
xFallenxCripplex
If no one else has a better explanation I'd t it using this spot but this is only going off of my photos in the bathroom that tube going over the top is from turbo going into the intercooler double check that connection is connected there some way
Sent from my Nexus 6P using Tapatalk
Sholab1
United States
Cheap is go to Amazon and get a panalong obd2 blue tooth adapter around 13.00 download torque pro on smartphone, I use the panalonhuse that till I got a better one OBD2link MX The view here is on my Samsung tab-E. No playing with hook-up of anything 6215529e710b87804c671e92692e7df8
Sent from my SM-G955U using Tapatalk
Yipeekayea
Could I use a leftover wifi only 7" tablet that has Bluetooth? I think I have one of the Samsung 8 or whatever tablets they coerce you into buying along with your new phone, however that was 2 years ago and the data plan has long been turned off, so it just sits on my desk collecting dust. ? That actually looks kinda cool, but I wouldn't have it mounted permanently, in good ole STL that would be gone in a heartbeat
Yipeekayea
Correction LG G pad 7, and it does have blue tooth, Wow I'd never heard of this before
xFallenxCripplex
As long as you have a Bluetooth obd adapter I highly recommend obdlinks products
http://www.obdlink.com/mxbt/
Best part of obdlinks mx is it has auto switch to hi and lo can
Also check out what else you can do
http://www.ecoboostperformanceforum.com/index.php?topic=6953.0
http://www.ecoboostperformanceforum.com/index.php?topic=3141.0
Also yes should be able to t into the line behind the blowoff valve for pressure
Lostneye
NY
I have the obdlink wifi one, since the Bluetooth ones don't work with iphone. Not as cheap as the Chinese crap but it's been great so far.
xFallenxCripplex
Yes true get WiFi if you own an iPhone!
odd I guess iPhone is so locked they can't transfer much data by Bluetooth
Julian Moore
In A Van, Down By The River
I have the autometer ODBII dashlink and it works great. Runs bluetooth from my iphone, samsung and ipad between all three of my cars. I have a different gauge set for all my cars. A little pricy ($150) but I wanted the ability to switch the gauge faces to match my hardwired autometer gauges.
Sho-Me State01
Does the Amazon one work well or am I better off buying the mx for $75? Going to run toeque pro w my Samsung phone ...
Sent from my SAMSUNG-SM-G935A using Tapatalk
Sholab1
United States
Belive the MX is faster, and shows more was much better than the cheaper one. Son uses my old cheap one on his vw now. There were some ford extra pid's don't remember if they were downloaded. SHOdded should know,
Sho-Me State01
Looking at getting the obdlink lx it's only $50
2012korn
Who's tune are you running? If you have a SCT device. Just use that for gauges.
However you're going to want to T off of the brake booster line from the intake manifold. The lines off the charge pipe will only show you boost not vacuum.
Yipeekayea
I ended up setting up torque pro on a tablet with a vent mount. works awesome. somehow my 91 octane one tune feels and IS stronger than the 93 octane tune. according to torque pro, I was running around 16.5 pounds on a really hot humid day here today. Does that sound right?
2012korn
Just because one tune has more boost doesn't make it stronger......if you have 16.5 psi at only 17* of timing. That will make less power then 13-14psi with 23* of timing.
SHOinVa
Tidewater Va
I just bought a $40 tablet at Best Buy and loaded up the Torqpro so I am figuring it out, but is there a oil pressure gauge I am missing, because I cant find it. I have a idea what I want to see but any suggestions on set up would be welcome. As always you guys rock.
Charlie
SHOinVa
Tidewater Va
How do u have it setup ? Pics?
Not really set up yet, I am going to try and mount it in the dip in the dash if the mount will hold, I have one on order from Amazon. If this works it will be the most for the money upgrade I ever did, Dongle=$12.59, Cheap Tablet=$40.00, App=$5.00, Mount=14.97 $75 and you have just about any gauge you want, LOL Except oil pressure for some reason.
C/
xFallenxCripplex
C/
Yea Ford didn't think we needed oil pressure or temp ☹️
