Where Can I Find A Supercharger
shopower90
Fosston
I am lookin for a supercharger for my 1990 Ford SHO MTX, i have looked and dont exactly know where to find one.. :shrug:
shopower90
Fosston
what would you go with, i am an old school V8 fan and like the supercharger, but would a turbo give me the most power? and well the least about of internal work?
ghostrider
Mt Juliet, TN
Most power and lest amount of internal work is kind of a catch 22. If you want the most power you can get, you will want to go all out. Lowered compression pistons, injectors, tuning, tranny work, suspension work, brake work. Everything. If you just want more power then you have right now, and are going on the cheap, I would say the turbo kit is probably the cheapest of them all. Any of these kits require some sort of serious work.
shopower90
Fosston
well lets say i wanna run 6-8 psi with the supercharged/tubro charger? just not run as much psi?
SHOMurph
Ford B@stard
Arlington, TX
North Texas Performance aka TexanTony will have a supercharger kit within a few months.
jedhead
westminster,ca
The former SHO Shop kit we will offer will come with just the pipes, bracket and oil lines or as complete kit. The complete kit will contain everything needed to perform the install ie: fuel injectors, fuel rails, LPM, MAF and so on, it won't be cheap though.
Bob
jedhead
westminster,ca
The 9 lbs kit went for $4500 from the SHO Shop. Included a 255lph fuel pump, 47lbs injectors, brackets, pipes, hoses, LPM, 80mm MAF, blow off valve, and all the necessary hardware. If we can get better prices from our vendors we will pass the cost savings. Don't forget that you will need to upgrade your clutch and a Quaife TBD is recommended. This will push the price over $6000. This price does not include installing all the stuff.
Bob
