What is the size of the bolt pattern on these damn things? I remember thinking it was 5 X 108? I found a set of wheels that are 18 X 71/2, with offsets of either 35, 42 or 48 and a bolt pattern of 5 X 100 or 114.3. Would these work?
IMO 35mm just sticks out to far from the hub compared to stock you would be better off trying to find a proper fitting wheel than whatever is easier on the wallet.GreenBird:
You could use those wheels with the 35mm offset if you re- drill your hubs and rotors. 5x114.3 is the 94+ mustang pattern, among many others.
