wheel bolt pattern
blk\blk90
TX
What is the size of the bolt pattern on these damn things? I remember thinking it was 5 X 108? I found a set of wheels that are 18 X 71/2, with offsets of either 35, 42 or 48 and a bolt pattern of 5 X 100 or 114.3. Would these work?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
SHO Bolt Pattern is 5x108 or 5x4.25 with a 38-42mm offset. The wheels you mentioned will not work.
GreenBird
Barre, Vermont
You could use those wheels with the 35mm offset if you re- drill your hubs and rotors. 5x114.3 is the 94+ mustang pattern, among many others.
RI-SHO
B to the BANNED
Pawt., RI
GreenBird:
IMO 35mm just sticks out to far from the hub compared to stock you would be better off trying to find a proper fitting wheel than whatever is easier on the wallet.
5x114.3 should be made a standard wheel size every type of import share this bolt pattern from your lower class accord to new Lexus, and a few domestic cars use this bolt pattern too.
