Huntervf
Bored now
My 93 ATX has developed an odd thumping/rattling noise coming from the passenger side front. It's most noticable over small washboard type bumps where the suspension is working but not taking any hard hits. When this happens it almost sounds like something is deathly loose and on the verge of falling off. It already has new ball joints, stab links and tie rod ends and an inspection of those articles proved them to be just fine. There is however some movement in the passenger wheel. With the car jacked up and my hands at 12:00 and 6:00 on the tire, the "wiggle" test gets me a touch of movement along with a subdued tapping sound that could very well be my noise when moving. I further disassembled the front wheel and got this same subdued tapping sound when hitting the axle & axle nut with a rubber mallet.
The other side has no movement and makes no noise at all.
The car isn't making any other noises and it drives just fine, but this rattle/clunk really bothers me. Does this sound like a bad wheel bearing to anyone else? And if it is, what kind of a repair job is this? I was once told that the spindle has to come off and the new bearing is pressed into it, yes? Does the SHO use the same bearing as a regular Taurus? If I'm going to a shop for this work I want to make damn sure I have all the necessary info ahead of time.
