Wheel bearing and hub
SonicRiot
Handbanana!
CT
Long version: Short below!So I figured out my noise was a seriously screwed up wheel bearing. As in flopping around. The noise and vibration progressed so quickly, I knew it couldn't have been the axle. Glad I dissasembled it first.
SO, I bought a wheel bearing and hub assembly. I called the guys I know at Ford and kindly asked them for a wheel bearing. He said it was a sealed unit. I replyed that the bearing was sealed, not the hub to which he replied that I was wrong and that the assembly costs $140, even with my dealer discount. Oh, and it wasn't in stock.
No thanks.
Called Fair Auto. They said they ONLY sell it as a repair kit which includes the hub with studs, axle nut, retaining ring, and bearing. It was some strange brand of hub and they asked $100 for it, discounted.
No thanks.
SHORT VERSION HERE!
Called the boys at Exact Auto. They also said it comes as a repair kit, but the bearing was a seperate, sealed Federal Mogul bearing. Awesome, somebody who knows what they are talking about. They delivered it to my dealership in good time and out of the box came a bright new National Hub, the retaining ring, axle nut, and the bearing, unpressed from the hub. It was only $86.
SO! Now I have to press the bearing out of the spindle (tommorrow's job), but should I bother replacing the hub? The bearing has a seperate inner race, so the only thing I can see going wrong is the inner race getting seized on the hub. Should I save the $40 and send this pretty little hub back and just press the old hub out of the old bearing?
Thanks.
P.S. Tips are awesome.
SonicRiot
Handbanana!
CT
Nevermind. The inner race of part the bearing cocked and shredded the stub shaft. Apparently this is not uncommon with Fords, which is why it is replaced as an assembly.
BTW, for those of you who don't know:
Removal
1. Remove C-clip
2. Press stub shaft from inner race of bearing
3. Press bearing out of the knuckle the OPPOSITE way
Installation
4. Press bearing into knuckle
5. install C-clip
6. Press stub shaft into bearing by pressing ON bearing, not down on the stub shaft (prevents pushing the inner race out from bearing)
7. Make sure the assembly spins smoothly and noise free.
It took me a couple of minutes to figure this out. Never done a wheel bearing on a Taurus before.
:thumb:
