sdpatt:
Read this description of the knock sensor code.
225 (R) Knock sensor not tested (ignore if not pinging)
The knock sensor only generates a signal when it detects a knock. If the engine does not generate a knock during the goose test (most often it dies not), then the code will be displayed. This is only a problem if you have been hearing continuous knocking during certain engine operating modes. In other words, no worry, mate. </strong>
Unfortunately this is incorrect. During the KOER test, the test advances the timing to create a ping so the sensor CAN detect it. If it doesn't it will throw the 225 code. You need to replace the KNOCK SENSOR. Below is the way it works.
PURPOSE
The Knock Sensor (KS) is used to sense ignition detonation (ping) and to supply this information to the Powertrain Control Module (PCM ). The PCM uses this input to optimize ignition timing while reducing the occurance of spark detonation and minimizing the amount of Oxides of Nitrogen (NOx ) produced in the exhaust.
CONSTRUCTION
The sensor has a thin circular piezoelectric ceramic disk that is bonded to a metal diaphragm. Electrical connections are made through a two pin integral connector.
OPERATION
The sensor is designed to resonate at approximately the same frequency as the engine knock (5-6 KHz). As the piezoelectric disk resonates it converts the sound vibration to an electrical voltage with an equal frequency. This signal is sent directly to the PCM.
The KS generates its own voltage and does not require a separate power supply. The PCM supplies the sensor ground through the SIG RTN circuit.
RELATED DIAGNOSTIC TROUBLE CODES
DTC 25/225 - KS signal was not sensed by the PCM during the Key On Engine Running (KOER ) self-test.
<strong> NOTE : During the dynamic response (snap throttle) portion of the KOER self-test the PCM advances the timing and checks for a corresponding output from the KS sensor. </strong>
As far as your ACT....Do like Naval and Scott said.
Now on your MAF issue...I missed that you had a 73mm. Since you don't have an LPM then yes I suppose it could cause the code but see that you were have the check engine lite on on full throttle acceleration only...none of the other codes have anything to do with that. That would mean if it was normal for the check engine light to come on due to the MAF beaing a 73mm then it would have happened from day-1 of installing your MAF. You could always install you 55mm MAF back and see what happenes to the code.
Jason
<small>[ April 30, 2002, 09:41 PM: Message edited by: Shoman94 ]</small>
