whatautomatic tranny fuild?
38SHO
#1 Oil Abuser
North Palm Beach
Mercon/Dexron III should be spec
if you really feel like spending more money... you could probably use Mercon V
but I wouldn't go anymore then that...(such as a full synthetic fluid like Mobil 1, Amalie...) waiste of money...
better off getting a good cooler
38SHO
#1 Oil Abuser
North Palm Beach
they do, and they also run through the radiator if Im not mistaken
your best bet IMHO for someone in a warmer climate... IE not canada who drives the car in the winter.... because those radiator coolers actually make the fluid hotter when need be... when its cold tranny fluid gets like syrup and jelly... so it needs to be a certain temp atleast...
so if u don't have -20 temps... put fittings with barbs on the tranny cooler fittings on the case and buy new line to fit those and run into the bumper.... don't kink the line too hard... then get one of those endtank to endtank side to side coolers..... NOT the kind where it keeps coiling back upon itself like an AC condenser... you want the kind that more looks like a radiator with two endtanks on the side.... FORD makes some decent ones actually stock on their big ass E40D tranny in things like F350 E350 etc..
sho_ted
Albany, NY
thank you.
93rev2sev
Hockeytown
I'm guessing you have an automatic? I have to guess because Automatic Trans Fluid is used in the MTX cars as well...
I will have to disagree and say (having lived in the great white North) that putting synthetic in there will be a definite advantage if the car is used in the winter. I'd suggest the Mobil 1 atf, which is "both" Mercon/Mercon V.
ultimatesho
Fort Bragg, NC
honestly we could all go on all day about what works best for us......but honestly each car each tranny each driver is different........what works for some wont work for other
me personally i HATE mobile 1's tranny fluid and LOVE valvolines...........but at the same time i no others who r the complete opposite
u just need to experiment to c what works best for u
crystizel
