I wouldn't run more toe-out in front, you will naturally get a bit with a static toe setting at zero.
Ron, This is due to the FWD pulling the assembly forward, yes?
How should I setup (non-track-dedicated) SC's and SHO's for good road race comportment but still serving DD status too without wearing the tires excessively, or at least weraing them evenly.
Okay, I was debating about running any toe out or not. I will probably leave it at zero toe for right now.
Then I will set my camber at -2.5* in the front and -2* in the back. From there I can monitor tire temps and wear to determine what adjustments to make.
I have an IR temp gun, but have heard that they are not accurate to use when reading tire temps. What kind is recommended?
My understanding is that you want to try and have your tire temps be consistant when comparing the inner and outer sections of the tread. This means that you are working the entire width of the tire evenly and maintaining the largest contact patch, which equals more overall traction. Of course this is just a general theory and has to be tailered to the aspects of the individual vehicle. Thoughts?
Also, what effect does a cool down lap have on monitoring this? Does it skew the reading since you are not really working the tires on that lap, or is enough heat retained in the "hot" areas of the tire to still gather accurate data?
Reviving this cause I need to go over both SHO and SC in preparation for a few track days this summer. I'd really like to figure out how to set both these platforms up alignment-wise. Can't seem to find anybody with alignmnet equipment who will work with me to get it dialed in.
I guess I need to have a target setup to tell them, relinquishing them from responsibility for how it performs after, then there's always the "gotcha"...
Oh! We can't get to your spec Mr. Gates, with your car lowered we can't move this side enough.
Oh! We can't realign your subframe Mr. Gates, you'll have to go elsewhere, have that done and come back for a re-alignment.
You know you really shouldn't be messing around with this stuff on Illinois roads Mr. Gates, you could **** somebody, you're going to shred your tires with that setup Mr. Gates.:argue: --->:idiot: --->
I suppose I need to learn how to align my own $#!+ in my own driveway and sort it out myself! Build an elevated wood alignment rack and get out the laser level...
