What size mufflers?
Dwayne614
I want aftermarket mufflers what size does a 2011 take? Is it 2.25 or 2.5? If I got a 2.25 X pipe the mufflers would have to be the same size correct?
SilverSH0
So If I wanted to change everything I should get size 2.25 X pipe and mufflers?
What do you mean change everything? If you're going to change everything then I personally would change everything up to 2.5" tubing. If everything is changed you might as well open it up a bit since stock size doesn't matter with everything changed. What are you trying to do? Are you trying to change everything from the downpipes back? Meaning tubing, x-pipe, and mufflers. Or are you simply trying to weld new mufflers and a x-pipe into the stock tubing?
Dwayne614
All I want to add is an X pipe and new mufflers. Maybe do a 3rd cat and resonator delete
