Its depends on how much time and space you have too... Spare parts take a lot of space for mine...
Gamefanatic makes a good list, here is my 2 cents.
- Front and rear bumpers (SHO uniques), yes the front too if its in one piece, the damage seems to be repairable, because the car has the higher probability to be damaged there (trust me, I damaged 2 in 1 summer...)
- rocker panels, the plastic part under the door (SHO uniques)
- doors ? (usefull if you have the space), if not, mirrors at least, could break because they don't move
- IMRC (could fail)
- Vanity cover (they broke)
- Galipers and pads, if good
- "A/C" relay for SAI pump (they broke), worth around 80$ used... placed near the pump (on the pump assembly, not sure)
- the keyless entry pad on the driver door (will wear if used), but easier to find for a 99, other fords had it too (for 96 its more complicated, different setup, 1 year only)
- Starter, they had one wire different from other taurus... You can replace it by a DOCH SLO one but this wire isn't funny to modify at this place...
- driver door trim with all the buttons in (assuming the 2 were with the grey interior), SHO door trim isn't the easier to find on SLO (if you have kids or want some, better to keep door trims...)
- electric doors motors (fronts and rear are differents IIRC)
- electric windows motors (expensive and could break)
- speakers ? MACH system have very few chances to break but they are very hard find now, not all the SLO had the "Premium"
- floor mats (SHO uniques) (don't forget the kids...)
- driver wheel (the leather will wear), leather version is hard to find on SLO
- leather seats (SHO uniques), at least you could replace the part on driver seat on his side facing the door, this particular place wear when entering and exiting the driver seat and leather will open there, I saw many with this problem, this part can be replaced as one part without retreiving leather (PM me for details)
- if you have time and space, sunroof (window and motor)
- valve cover bolts (SHO uniques and could break)
-> all taurus (gen 3 and 4 at least) have the same radiators (A/C too), not sure it worth the time
-> air blend door can be found on any SLO (including Gen4 with auto heater) with, doesn't worth the time to retreive it, better to find the last version of it on a low mileage Gen 4.
-> retreive the charger in the CD player BEFORE unpluging, it will be usefull to store another selection of CDs in your SHO (like an automatic gun, its always usefull to have a full charger ready to put in !)
-> Good alternators can be find on Ford Explorers of similar years (same casing) and are easier to unbolt (and less destroyed by water and dirt on top of the engine)
Personnaly, I'm in search of a A/C hose, not sure of the name, the one starting at the rad and going to compressor (but I can live without).
Good unbolting,
