What Do Ya Do With a Bad Tranny
BenBrausen
Minneapolis, MN USA
My current tranny is on it's way out. I got a new tranny that will be installed soon. So what do I do with the old one? Is there any place that'll buy it? That'll take it? Is it something I can keep and learn how to rebuild myself?
BlackOnBlackATX
Dutchess County, NY
well, if you dont have to turn it in for a core charge then if you have the room and tools id keep it and mess with it. or have it refabbed and beefed up for the day you drop that supercharger in your SHO youve always wanted :D im not too sure about anyplace that would buy them but get in touch with the other SHO shops that sell tranny (FPS, SHO-shop?) and ask em, maybe they need a core and theyll throw you a few bucks. or you could always sell it on ebay of course.....
Mr Anonymous
Tire Wall
I seem to recall someone mentioning that Doug at FPS would buy '94+ ATX cores for like $200, although it would probably cost that much just to ship it to him. Maybe he has a deal worked out with a freight company. Wouldn't hurt to call him and ask. You might even find a forum member willing to buy it as a rebuilding project.
BenBrausen
Minneapolis, MN USA
Where can I find a manual that'll show me how to rebuild a SHO tranny? Or do I have to get a generic book? Would I trust a tranny I rebuit myself? shrug Heh heh heh...
Bluto
Rochester, NY
Buy a chilton, or haynes, or anyone that explains the AXODE tranny. Its used in a lot of Fords.
rangerj
Brunswick, Ohio
Ben,
The best reference source for rebuilding a Ford transmission is the Helm service manual for make and model year. Any upgrade kit you buy will have a set of instructions explaning the differences between OEM and the kit parts, or proceedures.
If you take it one step at a time, and label everthing, it is not that complicated. There are a lot of spacers that have to be measured by micrometer, and placed in the proper order as the trans is reassembled, but this is not bad if you follow the book.
There are a number of valves that are hydrolic, and the pistons are sealed in the bores with O rings. But if you do these one at a time the hardest part is getting the snap ring in place.
The two clutch packs should be labeled as they are removed, that is 2nd, 3rd, then 1st Rev. The same for the bands. Then you can remove and replace the clutch plates and friction disks in each pack as a unit. Keep the labels on them until they are ready to be reinstalled.
There is not much to do to the valve body other than clean it and check for broken springs. If you take it apart, you do not want to get any of the parts mixed up. Again, use labels.
There are some special tools required, but only a few, and they are not drastically expensive. (Spring compressors)
If you go into the differential and bearings you will need some additional "special tools". I would leave the differential alone the first time, unless you know you have some bad gears or bearings, etc.
If you think the torque converter needs service, take it a shop that specializes in servicing torque converters. Balancing a torque converter, and other services take a whole lot of special equipment, as well as special tools. This usually is not necessary.
The real trick to the trans is putting it back together in the reverse order it came apart, and putting all the "O" rings and seals in where they belong. There is also a little precision measuring involved, but no "rocket science".
A good rebuild kit is about $300, so this would not be a cheap experiment. But, putting an automatic trans back together and have it work is an exhilerating experience. Try it you'll like it! rangerj thumbs_u
PS I put my first one in three times before I got everything right. That means I pulled the sucker out four times. I finally found a piston cocked in its bore. :confused:
My nephew is driving the car and that trans has 165k on since the rebuild. The fluid and filter has been changed twice, and the bands have been adjusted with each fluid change. No other problems! Knock on alumunum!!! :D
Bizzy
I just got my 3000 page helm manual for 94 Taurii and I'm gonna possibly use it to rebuild the ATX in my 95 SE. Course I did also plan on sticking a SHO ATX into my SE, but i'm not sure if I wanna do that, or challenge myself with rebuilding the dead one in the car now. I did contemplate a SHO swap to my SE, but somehow it wouldn't be the same. I notice SHO's I don't notice the SLO's anymore.
From what I understand, transmissions aren't that hard to rebuild, you just have to make sure you do everything in the right order and by the "book"
BenBrausen
Minneapolis, MN USA
Once I rebuild it, what would I do with it? I'll have my new one in by then. No one would by "My First Rebuild"... I could rebuild it with a Trans-Go kit in it. Sell it on eBay...
rangerj
Brunswick, Ohio
Ben,
You could find some kind of antique wroght iron plant stand, mount the rebuilt trans to it, and put it on display in your living room! Like a work of art, or some antique piece of furniture.
Mine would not buy that either!!! The early 1900s Singer sewing machine she has on display is an "Antique", and it creats "interest", but anything I want to display is "junk". Go figure!!! rangerj" shrug
