Hello all,
Hope someone can help with this question. First,I have a 99 Tuarus and the alignment on the car was straight as an arrow with my old tires. So, I just bought 4 new All Season tires. I had to return back to the garage twice to have two different tires replace with the exact same brand of tire because of a rotational "wumping" noise coming from them. Ok... no more noise but now the car pulls to the right at any speeds. So I return back to the garage regarding this problem. They suggested that we first rotate the two front tires to see if it continues to pull right or does it pull left. If it pulls left they will replace the two front tire due to a "radial- pull". The mechanic also recommended that the lower ball joints need replacing but not right away but soon and a wheel alignment, I decline for now. I leave the garage and the car does not pull right anymore but it does pull left at highway speeds and I take the highway everyday. I go back to the garage regarding this problem and now they tell me that they will not warranty the tires until I have the work that they recommend done first because they feel the cause for the right and left pull is due to the lower ball joints need replacing and a alignment done. Lastly I have all the work orders with the promises and recommendations writen on paper.
So, after all that is explained. What do you think... Suspension/steering problem or defective tires?
Thanks for all responses.
