PIMPOLOGY
What type of material can be use to scrap it and see if there are any chunks from the bearings left on there?
If you go this route, make damn sure you plastigauge the new bearings.Lorenr said:Polish your crank yourself.
Use 600 grit wet or dry oxide cloth. Get it at a parts house. It comes as tape that should be the same width as your journals.
Cut a piece that will wrap around the crank journal about two times.
Soak it in solvent or even paint thinner.
Wrap a leather shoe lace twice around the oxide cloth. Pull on each end of the lace alternately.
It will polish the crank, expose any imperfections and remove them if your lucky.
Take your time and only do this until it is polished.
yamahaSHO said:If you go this route, make damn sure you plastigauge the new bearings.
NotSoSlowSHO said:if the journals are worn too small according to plastigauge, you simply use undersized bearings (thicker, smaller bore)
I got pics but they didn't come out right because of the glare from theyamahaSHO said:Do you have any pics of what you are talking about?
Here ya go.yamahaSHO said:Do you have any pics of what you are talking about?
