Welp what do yall do for this stuff?
greenbeanmtx
King Skidmark
Waco Tx
Well greenbean has finally fallen to the oil in the wells and i guess aided by the 20 degree temp. here today ive finally started feeling a slight stumble upon light throttle. My wires are only about 3 months old so im not going to replace them but i will be replacing the 5 month old spark plugs provided they dont look good since they have been submerged in oil. But heres my question for yall:
where is the best place yall have gotten plug well seals? I understand you have to get them with valve cover gaskets and thats fine with me, but as far as price and time to get them in is my concern. I only have next week off so i will have to do it then and i dont want to wait weeks for the things to come in or something. Thanks everyone yalls suggestions are much appreciated. And Everyone have a Merry Christmas :)
SASHO91
Zoom Zoom
San Antonio,TX
um, Napa, and adavance.... comes with VC, and oil seals...
a tip for the oil, take a squirt bottle, and put the end in the well, then start squrting into a bottle... It helps alot!!
hey karson, do you need anyhelp? i would like to get the twins together a take some pics.... i wouldnt mind the drive either...
I just did this on a 93 ATX last Sunday... I still have it freshin my head... so i know what im doing... and i just took my intake off..... im not impling that you dont know what your doing, but its always good to have another showner around....
greenbeanmtx
King Skidmark
Waco Tx
Yea i forgot to mention that ive been sucking the oil out of the wells on a monthly basis but havent done so yet because its a bit nippy now........
Saleensho, ive got a job interview tuesday so i wont be able to work on mine until roughly wednesday on next week......... depending on when i get the parts in is when ill get started on her.........ive done this process myself on the 89 for my sister but autozone had them in stock and i got the last set and it was on her bill so i just got them and left...... They said in the future they would have to order them so thats why i asked about what yall use....... I doubt you and i will be able to rig up a time to work on it together but im up for getting the twins together for a shoot...... have you found out when your comming up for the meet? Mine is pretty much already clean so whenever your up for it just hollar at me and we will take some shots of them. Thanks for the offer though, ive done it though and actually have the video that shows u too Thanks man :thumb:
jelloslug
Digital
Greenville, SC
If price is a big factor I have a set of slight used ones (10k-15k miles on them) that are in really good shape. I'll let them go really cheap. Let me know soon and I can put them in the mail tomorrow (12-24).
greenbeanmtx
King Skidmark
Waco Tx
Alright excellent........ Let me know a day or so before u leave and depending on weather and all we can meet up as you come up or when ur headin back..... The twins need a photo shoot :thumb:
bgjohnson
iowa
hey i just did mine about two days ago along with shimming my valves, new acces belts and tightening the timing belt and new plugs. and it's not too bad except the rear valve cover, that thing was kinda ***** to do for me. and here's and little somthing to help seal it better, when you push those new seals into the valve cover, put RTV sealer on them, and also between the heads and seals. it seals perfect:)
Electricat
Decatur, IL
I don't see any reason you should need to replace the plugs themselves, if money is short. They might be a bit gunky from the misfiring, but just clean them up, check the gap, and put them back in. Brake cleaner works good for this, as it removes oil without leaving a residue.
BTW....your avitar is absolutely grotesque!!!!!!!
greenbeanmtx
King Skidmark
Waco Tx
Thanks about the avitar.........ive had that on there for a while and no one commented until you! I figured it would add a bit of flare to put a picture of myself on the avatar that way yall know what i look like :naughty:
91 Plus
Well-Known Member
Monroe,Michigan
The easiest way I found to take the oil out is this..
If you have a air compressor put a rag over the hole and spray air down in there. It shoots all the oil on to the rag in a matter of seconds!!
