Weird noise from rear
Jesse
ohio
im having some kind of squeeking noise some times when i start up and take off. Its not a loud squeen. But very anoying. It comes and goes. Dont know whats causing it.
Its been doing this since i went off the road and got pulled out. I cooked changes on those hooks under the rear. Could this have caused the noise?
rangerj
Brunswick, Ohio
Jesse,
I had a similar problem, turned out to be the mother-in-law in the back seat! Talk about annoying. :D
Seriously, look for something in the suspension rubbing the wrong way (pun intended). You may have knocked somthing out of kilter (technical term) either when you ran off the road, or in the process of getting pulled out.
Look for "rub spots". If you can, put the car up on a lift so you can make a good inspection of the suspension. You may have to have it put on an alignment machine to find out what might be bent.
This would be a last ditch (pun intended) effort, if you can't otherwise find the source of the annoyance. LOL rangerj thumbs_u
Forgive the humor!
poffffd
