Kirsch95MTX
Curb Crusher
Ive been reading around the search and have actually posted a couple times already about the tranny in my 95 mtx. I had a grinding issue, all gears. I just had a new clutch put in and the shop discovered the tranny was fluidless. I dont know how long the PO had been driving the car around without fluid, he told me he parked it once it started grinding. Now there is a new clutch and fluid in the tranny. The car drives fine just barely grinds at the end of the 1-2, 2-3, and 3-4 shifts. The higher the gear the quieter the grind and there insnt any grind going into 5th. Also when i say grind it doesnt really grind just kinda zips at the end of the shifts. Does this sound like synchros or blocking rings? Could it possibly be a clutch cable or linkage issue? Also noteworthy when i pull the car to high rpms in any gear and quickly depress the clutch pedal it feels like the bottom falls out of the pedal, there is no feel or resistance whatsover. Does this sound familiar to anyone? I just cant help but scratch my head. The tranny shop wasnt much of a help in diagnosing any problems either.
I figure it wont hurt to change the fluid to syncromesh since im sure the shop just used cheap crap. Is there anything else i can do? Ill double check the cable even though the shop said it was good too. Im not ready to rebuild so if it is the syncros or blocking rings can i get a little but of mileage out of it if i put good fluid in the tranny?
You just have to angle the hose into the transmission correctly.
