Vibration in floor/pedals
Redskull
Badass Mo'fo
New Haven, CT
The newest problem: there's what seems like a vibration/rubbing/slight scraping i can feel through the floor, the gas pedal, and the steering wheel. You can't feel it at low speeds, but it starts becoming more apparent around 20mph. Between 25/30 it's very apparent, with the rubs about twice a second. Faster then that, it seems to dissapear, or at least becomes to fast to notice. The car doesn't shake...the floor just sort of 'hums' like it has too much bass (yes, the subwoofer is unplugged :nut: )
It's definitly speed related, not RPM related, and rotating the tires around didn't help. All my hot supermodel passengers tell me they can't really feel it on the passenger side. I did find a small hole in the CV joint boot....am I in the market for a new set of joints?
Ishodu
It could be a CV joint, I would also check all the suspension bushings and joints for any ware. With a hold in a CV joint its life is very short from here on it, best you get one to install.
