Valve Stem Seals?
roswell998
Atlanta, Georgia
A friend is considering purchase of a 94 3.2 atx and said that it blows blue smoke for about 30 seconds when first started after sitting overnight. Seems to be heavier if the temp is lower (like in the low 50's rather than in the 60's or 70's). He ran compression check and said results were fine (I don't have the numbers).
1.....Could the above be something else other than valve stem seals?
2.....If it is valve stem seals, are Felpro seals of high quality?
Thanks
EDIT:......forgot to say that smoke blows from exhaust, not dripping anywhere.
AREA 91
PA SHO SHOP
Area 91
Sounds like the classis valve stem seals to me. In my opnion Fel Pro makes very high quality gaskets. I use em. :thumb:
roswell998
Atlanta, Georgia
Specifically, have you or anyone else used the Felpro valve stem seals?
I've also used Felpro gaskets in other areas and have been pleased so far.
DHMag
Free At Last
InCahoots, Texas
Fel-Pro valve stem seals on my car for 14 months now without a single problem. regardless of the application, Fel-Pro gaskets/seals CAN be trusted.
jelloslug
Digital
Greenville, SC
I would go so far as to say that the Fel-Pro seals are the same as the Ford seals. They sell lots of stuff to Ford.
roswell998
Atlanta, Georgia
Thanks Guys! :thumb:
If he buys it I will help him install the valve stem seals. From responses so far he will plan to get the Felpro seals.
Again, your replies are appreciated.
