Using the maplight for power
jthomas68
Area 51
I`m going to run a radar detector direct from the maplight power.What colors do i tap into for power and ground,i seem to only remember 2 green wires,although it`s been a while since i`ve been into it. shrug
marlonius
Holden, MA
I could be wrong, but I think the metal plates that the bulbs are mounted to act as the ground. I say this because when I've taken the screws out to take the overhead console down, the map lights would go out once the metal-to-metal contact was broken. So I think you are correct when you say you only remember two green wires. I hope I'm making sense.
jthomas68
Area 51
I beleive you are right about the ground being connected to the bracket itself.I would *think* the 2 green wires are both power,but the green kinda throws me off.
Why not use the moon roof power as it is switched by the ignition?
jthomas68
Area 51
Sorry Paul,that`s what i meant,power from the maplight/moonroof switch assembly.I di need it key switched so it will turn off with the ignition.The purpose it to have the detector to go on/off with the car.I think i got it all figured out.
