Upgraded headlight harness??
TopSHO92
Minnesota
I was wondering if anyone can tell me where to get one of the high wattage wiring harnesses for my headlights? ...and how much??
Thanks~
'92 SHO Black
*Tokico struts, Eibach springs, 24mm frt. & 26mm rear sway bar
SHO Shop: tubular control arms, H-brace, heavy duty swaybar connecting links, poly bushings all the way around, subframe bushings, heavy duty motor & trans mounts, & solid torque limiters
S
SHODOG220
Guest
hehe, good choice in SHO's
Anyway, go here: http://www.xtremewhite.com/LBU-light~bulbs-Spw-1-1-1-1-1-1.cfm you'll see about midway down it says "Heavy duty harness for H4 and 9000 series light bulbs" its only 25 bucks which is a LOT less than I payed for mine from my local ricer shop. I had one in my 91 but it got all corroded so I had to take it off. For my 92, I just went with some Heliolite stock wattage light bulbs from that website up there. They are a real nice color and are pretty bright for what they are if you don't want to bother with the harness. The problem with the harness is that once you put it in, it'll trick the car into thinking you have a headlight out eventhough you don't so whenever you have the headlights on, the "lamp out" light will be on on the dashboard. I got used to it after a while personally.
92 black/black MTX, 48k miles, SHO SHOP Y-pipe, silencer box removed.
91 White/Black MTX: Dynomax catback/Summit Turbos, K&N Filter, Boxless, Kuhmo ECSTA 225/55VR16 tires, Centerforce Dual Friction Clutch/Grizzly TOB, SHO NUT Motor mounts. SHOCAGO Member
http://www.picturetrail.com/shodogg
