gipraw
Pro Detailer
Search didn't turn up much, especially recent.
Has anyone found a replacement pad that is an improvement of the stock PP pads?
Have you checked AutoAnything &/or TireRack?
I got Power Slot Rotors (today) from TireRack & EBC Red Pads (back ordered) from Auto A. for my Brick.
Bob, I hope you have god luck with the Power Slots, could be I had a defective set. I really liked the EBC Slotted/Dimpled Rotors a lot. I will try to find a picture of the bad rotors, just so you can see the problem I had with them, but I certainly hope they work great for you.
I don't do tracks or hard braking, this was on a daily driver, that was driven pretty easy, and it's not just the corrosion, but the machined surface of the rotor was actually "eaten" away. No there was never metal to metal contact. For a rotor that was almost 100 per, I don't think it held up at all. Especially considering that both the stock and the EBC rotors after that worked and lasted much longer. Well, the stock rotors did warp which was why the got replaced with the Power Slots. Anyway, I guess my point is that there was no time that these rotors sat unused for more then 1 or 2 days, so there was no reason for corrosion on the braking surface. However, I do understand them corroding to the hub, and the 2 tapped holes would sure make removing the rotors much simpler.
And chances are those other rotors weren't warped. 90%+ chance that they had uneven pad deposits, and a cleanup pass (plus some new pads) would have corrected it.
IMO, you are making an assumption that, since you paid ~2X (my guess) the cost of a standard rotor for the privilege of having them put some grooves in them, that they should last longer.
No the stock rotors were warped, the were checked and also recut to bring them back into specs, before they became unusable. Also, in my experience, Ford rotors have a tendency to warp or wear very quickly. Also when the stock rotors were redone, they also had new pads put in the calipers. BTW, I also did not use ceramic pads, they are just too hard IMO and are harder on the rotors then a non-ceramic pad.
As far as the EBC pads Yellow stuffs are the track pad, Red stuffs are a ceramic pad. I'm a big fan of the Yellow stuffs. Have them all the way around on the Coupe.
I'll be due to change the pads soon as they start to make a squealing noise... Should I change the pads only or go for the whole package (disc and pads)? How much are we looking at more or less for complete job with improved performance?
Thanks!
